SiyonKart's avatar
SiyonKart
Follower
Aug 18, 2021
MK62 Question
Hey guys. Having some poor signal throughout the house with a single router setup. My question is since I already have a nighthawk router that I want to continue using, can I use the MK62 router as a satellite or do I have to set the MK62 router as a separate network in order to use the additional satellite? TIA!
1 Reply
  • plemans's avatar
    the mesh networks like the MK or the Orbi system need a controlling mesh router.
    so you wouldn't be able to "integrate" the mk into your system but you could keep your router and use it as backup or to offload the mesh network.
