Engineersaab
Feb 04, 2019Aspirant
Multiple home networks
I bought a dual band range extender planning to hook the home security system cameras up to the 5G network and leave it up 24/7, while leaving the kids phone on 2G, and restricting hours of operation....
- Feb 04, 2019
Engineersaab wrote:
I bought a dual band range extender planning to hook the home security system cameras up to the 5G network and leave it up 24/7, while leaving the kids phone on 2G, and restricting hours of operation.Since they'll only work on the 2.4G, why not put both the cameras and phones on that band, but then block the phones by schedule (instead of turning that band off during certain hours).
WHOA
Feb 04, 2019Guide
michaelkenward
Feb 05, 2019Guru - Experienced User
Good thinking WHOA, but check that this unnamed range extender supports this setup.
I have seen reports here of range extenders not having the same "parental control" features on many routers.
Might help if we knew the model of the range extender.
There is a manual for the R6200v2 somewhere at the end of this link:
>>>> R6200v2 | WiFi Router | NETGEAR Support <<<<
- EngineersaabFeb 12, 2019Aspirant
It is an AC1200 Range Extender.
More precisely, it is a Model EX6200 AC1200 Range Extender
