Please_Help_Me
Nov 12, 2015Aspirant
N600 Router Model WNDR3700v3 not connecting to internet
My N600 Router Model WNDR3700v3 which had previously worked is no longer connecting to the Internet. The Internet port light (in-between the Power and 2.4 GHz indicators) is a slow flashing amber light, not green.
I have followed the troubleshooting instructions in the proper sequence and also have resorted to using the "Restore Factory Settings" button. All to no avail.
I know the cable from the router to the modem (ubee from Timewarner Cable - my ISP) is good because when I bypass the router and connect the cable directly to my Dell Inspiron 15R Windows 10 computer it connects fine.
Your assistance is appreciated.
Thanks
Thank you for your input. Ended up buying a replacement.
- Retired_Member
Internet.....Internet setup...select .....Use Computer MAC Address..........reboot modem and router
do this using same PC which you used without router
Same problem........ I would replace the router
- Please_Help_MeAspirant
