cm632000
Apr 03, 2017Aspirant
N600 speed
I am looking to upgrade my cable modem since I was just informed by my isp that I have up to 100mbps incoming data speed. The tech specs on this model says it handles 600 (300 + 300). My question: ...
- Apr 04, 2017
The max wired speed will be 100mb and the wif speed will around half normally if your planing to go beyond 100mb you need a new router then this will work for a 100mb but at it's limit.
If you want more information about the router try wndr3400v3 not n3400v3 a firmware update may help some
Here is the firmware for wndr3400v3 router link https://www.netgear.com/support/product/WNDR3400v3.aspx#Firmware Version 1.0.1.8
cm632000
Apr 04, 2017Aspirant
Model # is N3400v.3
Thanks.
William10a
Apr 04, 2017Master
