nanc1234's avatar
nanc1234
N600 wireless dial band router WNDR3400-100NAS
Ten yr old router. How do I get it to work without plugging into Verizon router pls? Thx.
  • > [...] How do I get it to work [...]
       Define "work"?  What, exactly, would you like it to do?
    > [...] without plugging into Verizon router pls? [...]
       Did you expect the WNDR3400 to access the Internet with no connection
    to the Internet?
    • nanc1234's avatar
      nanc1234
      I need modem correct ? Yes was expecting router to access internet
      • antinode's avatar
        antinode
        Guru
           If you want an Internet connection, then you need an Internet
        connection.  That usually means an ISP.  The service from some ISPs
        requires a modem.
           Do you already have a "Verizon router"?
           Is there some actual problem which you are trying to solve?  I don't
        understand what you're trying to do.
