LouBu
Jul 17, 2016Aspirant
Need a router which allows Wifi to be turned OFF
Hi,
I need a router that has a Wifi on/off switch that will allow me to use it wired. Does the N300, or one of the others, have a Wifi on/off switch?
Thanks,
Louise.
- Retired_Member
Pick any router, and then go to the "Downloads" tab at the top of this page. Enter the model number and then read the manual.
N300 is not a model #
- VE6CGXMaster
Any router has that ability in their f/w.
All router have a kill switch to turn off wifi!
Push the switch and that's it!
