mitx's avatar
mitx
negative number in "attached devices"
Has anyone seen or have a suggestion on how to correct a negative number of devices in a WNR1000v3?  Firmware has been updated (version below)
Actual number of devices is 14 per list in detailed screen.  The summary screen shows "-27" as the number of devices count
I have restarted the router a number of times.
UPnP is turned on
I have a 6 devices setup as reserved addressed (Advanced; LAN setup)
Thanks for any advice or ideas.   Mike
Firmware Version
V1.0.2.68_60.0.93NA
  • mitx's avatar
    mitx
    Jan 03, 2017
    Hard to say which three devices in the detailed list are not counted in the summary total.   And the number varies.
    This might just be a bug showing up with certain configurations that netgear has never fixed.
    The device appears to be working in all other ways
    Thanks, Mike
    • mitx's avatar
      mitx
      Hi ElaineM,
      I have a lot of settings, if I use the save config and then restore config after a factory reset would that be a good approach to use?
      I would feel more comfortable with the save and restore to make sure I did not miss some setting.
      Thanks, Mike
      • StephenB's avatar
        It would be easier, but it's not a good idea.  If the settings are corrupted somehow, then save/restore would restore the corruption too.
        Though it's tedious, you can make screen shots of all the settings pages, and refer to them when you set up again.
