billu's avatar
billu
Tutor
Jul 19, 2022
Netgear 6300 - No WiFi Connections
Last night, my gateway stopped connecting wireless devices.  I have rebooted the device several times.  The gateway runs into a switch and the devices that are hardlined are functioning properly.  I can access the interface and it claims the wifi is being broadcasted, but I can not view the SSID (for both 2.4 and 5G) on my phone and other devices.
Any suggestions?
  • plemans's avatar
    What actual router do you have? There's a c6300, R6300, D6300
    What firmware is on it?
    So none of the wireless devices are picking up a signal?
    What are the led's showing for wifi?
    did you try hitting the wifi on/off button and holding for 2 seconds?
    What does it show if you log in through the browser for wifi broadcast?
    Did you try a reboot?
    A factory reset?
    • billu's avatar
      billu
      Tutor
      Its a c6300v2
      Firmware version is 1.03.04
      Not a single wireless device is connecting.
      LEDs are all green
      I have not held the wifi button down.
      Logging into the router, everything looks great.  Says its broadcasting the SSID like it has for the past two years.
      Several reboots
      No factory reset (yet)
      • plemans's avatar
        I would try turning the wifi on/off and see if that helps.
        If not, I'd try the factory reset.
