MauiScott
Mar 08, 2017Aspirant
NETGEAR AC1900 - How to change Default rout password, I have done this in past.. Can't figure it out
I have a netgear AC1900 I need to change the basic standard default password that is used to get into the Router. I'm not talking about the network password. It comes standard with Admin and "Pass...
TheEther
Mar 08, 2017Guru
Log into the router and go to ADVANCED > Administration > Set Password. This information is easily found in the manual and should be the first place to look.
- MauiScottMar 08, 2017Aspirant
Thank you for your help.. Got in and changed. : )
- William10aMar 09, 2017Master
I would never leave the user name and password or even wifi settings the default on gateway or router many years before this garage on web the about people being spy on you the next door house would steal your wifi because people left the router set to out the box settings nothing new just different players in the game with new toys.
