MauiScott's avatar
MauiScott
NETGEAR AC1900 - How to change Default rout password, I have done this in past.. Can't figure it out
I have a netgear AC1900 I need to change the basic standard default password that is used to get into the Router.  I'm not talking about the network password.   It comes standard with Admin and "Pass...
  • TheEther's avatar
    Mar 08, 2017
    Log into the router and go to ADVANCED > Administration > Set Password.  This information is easily found in the manual and should be the first place to look.
