GeminiJ13
Oct 25, 2017Aspirant
NETGEAR INC. vs. Krack WPA-2 vunerability
Dear NETGEAR, I can't even e-mail you to shame you on why it is that you haven't gotten a patch out to us to fix this CRITICAL vunerability with our routers. Are you that afraid of your owners t...
- Oct 25, 2017
There is a lot of FUD (Fear, Uncertainty and Doubt) and misinformation going around about KRACK.
It may help you to know that KRACK generally targets Wi-Fi clients, such as smartphones, laptops and PC's with Wi-Fi adapters. Also affected are range extenders/repeaters, which also effectively work as clients.
Routers and Access Points (AP) are generally not affected, unless they support fast transition, or if they are reconfigured to function as a bridge, range extender or repeater. Most of Netgear's routers don't support fast transition. AFAIK, the only exception is Orbi, and even there I believe fast transition can be disabled. So, while there is cause to be concerned about KRACK, the fault generally doesn't lie with your router.
As to support, yeah, Netgear's support leaves a little something to be desired, but it's probably par for the course for many companies to be difficult to reach. Live support is expensive and frankly not all that helpful. Answers are usually available on the Internet or here on this forum if you search. It wasn't very hard to find one of Netgear's advisories on KRACK:
https://kb.netgear.com/000049498/Security-Advisory-for-WPA-2-Vulnerabilities-PSV-2017-2826-PSV-2017-2836-PSV-2017-2837
TheEther
Oct 25, 2017Guru
- GeminiJ13Oct 26, 2017Aspirant
The Ether,
Thank you for the informative reply to my post. It went a long way into helping me understand what Netgear is doing with and for their customers on this important issue. Honestly, though, you shouldn't have to start a post and then have someone knowledgeable like yourself have to come in and explain what is going on. This should be front page news on the Netgear website for the foreseeable future. But, I am very appreciative for the help you gave to me and others. Have a sunny day!
- TheEtherOct 26, 2017GuruGlad to be of some help. It may not be front page news on Netgear's main website, but it is on front page of the Community page. It's currently in the Stories tab, second row. Yeah, that's not even close to being prominent enough.
https://community.netgear.com/t5/English/ct-p/English
