krish123
Oct 12, 2016Aspirant
NETGEAR N150 no wireless connection
i have router of netgear. now i connect my internet via ethernet cable but can't connect via wireless .so via wireless i can't connect any device .what should i do?
Sounds like its time to get a new router if you've exhausted all troubleshooting options with no change.
- ElaineMNETGEAR Employee Retired
- krish123Aspirant
i Can do all the troubleshoot but can't do anything resoponce from router
Have you been through the setup process described in the Installation Guide?
WNR612v3 | Product | Support | NETGEAR
- wcalifas831Prodigy
Can you tell us the model of the router? Also you might want to power cycle it first and if that doesn't work maybe you can see if there's a firmware update for it that could help resolve the wireless connection issue. Lastly you can do a hard reset by pressing the pinhole on the back for 30 seconds but you'll have to redo the setup. Let us know what happens.
- krish123Aspirant
model number
