jgenac
Sep 28, 2015Aspirant
Netgear N600 Sporadic Connectivity Issues - Wired
Greetings,
I've owned a Netgear N600 for almost exactly 1.5 years, it has worked fine until last week. I use a wired connection even though it is a wireless router.
Symptoms:
On regular 240 second or 120 second intervals, no data goes through the router for ~5 seconds - then immediately goes back to normal.
Buffered media streaming is not impacted. However, when gamaing this manifests in huge spikes. Sometimes I can receive data but not send data for a longer (~10second) period.
Diagnostics I've done:
Restarted modem and router - does not work.
Changed ethernet cable from port 1 on the router to port 2 - did not work.
Plugged my PC's ethernet directly into the modem - worked. Had it plugged into the router for over 3 hours and no lapses in data flow. When I switched back the issue resurfaced immediately.
Thanks in advance for the advice.
Hello jgenac,
Welcome to the community!
The connection seems intermittent whenever the router is in place.
Since you have upgraded to the latest, try to reset and reconfigure the router.
Push the reset button on the router for 20 seconds with a paperclip.
Resetting will restore the settings to default settings. Once reconfigured, observe the connection.
If the problem persists, try to lower down the MTU to 1400. To adjust the MTU, you may follow the steps from this link.
Looking forward to your response.
- jgenacAspirant
Here is a screenshot of data flowing through my router into my pc stopping at regular 4 minute intervals:
This happens with extreme consistency throughout the day, and does not happen when my pc is plugged directly into my modem via an ethernet cable.
Just tried a firmware upgrade to no avail.
Once again, this happens when wired via ethernet directly into my router or on wifi. I primarily use a wired connection.
Customer support is blaming this on a "config issue" even though I have not touched any settings on the router admin console, neither recently or when I first got it.- ElaineMNETGEAR Employee Retired
Hello jgenac,
