Koyoo's avatar
Koyoo
Netgear R6100 5Ghz network
So I was gone from home for a week, and just got back and noticed my 5g router isn't working. My regular 2.4ghz is, it'll load webpages and everything but when I connect to 5g, all it says is No internet connection, how do I fix this
  • Hi awdsawds,
    1. What is the firmware version of the router?
    2. Please make sure that you do a factory reset after updating the firmware.
    3. Only dual band compatible adapters/devices are able to detect the 5GHz band.
    4. Please make sure that the 5GHz radio and broadcast is enabled.
    5. There should be a 5GHz tab on the desktop Genie if it is enabled.
    6. Please check your other 5GHz compatible device/s.
    Dexter
    Community Team
  • Annnd now it says there is no internet connection to the 5g router
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi Koyoo,
      2. Are all your wireless devices that connect to the 5GHz band affected?
      3. Have you tried resetting the router?
      Dexter
      Community Team
      • DexterJB's avatar
        DexterJB
        NETGEAR Moderator
        Hi Koyoo,
        I would like to follow up and check if you are still experiencing the issue.
        Dexter
        Community Team
