erotavlas's avatar
Sep 13, 2015
Netgear WNDR4300: configured as AP via WiFi not LAN
Hi,
I have the Netgear WNDR4300 which is a double band WiFi router with the ability to set up two WiFi networks: one at 2.4 GHz 802.11 b/n and the other at 5 GHz 802.11 a/n. I know that I can connect it via LAN to another router or AP in order to act as WiFi extender. What about the possibility to connect it via WiFi to another router or AP in order to act as WiFi extender? For instance if I connect my Netgear WNDR4300 via 2.4 GHz 802.11 b/n to the router or AP and then I create a second WiFi with different name at 5 GHz 802.11 a/n. Is it possible?
Thank you
  • ElaineM's avatar
    ElaineM
    Sep 18, 2015
    Hello erotavlas,
    Repeating Functionality was removed in the latest firmware update due to security vulnerability.
    The only way to get the Repeating function back is to downgrade to the previous version.
    Hope this helps.
  • Using one Wi-Fi band to connect to another router and the other band for nearby wireless clients is called FastLane by Netgear.  You can read about it here.  It's not available on your WNDR4300.
    The WNDR4300 can function as a wireless repeater.  In this case, one or both Wi-Fi bands are used to connect to another router AND to provide access for nearby wireless clients.  As a consequence, wireless performance takes a minimum 50% hit in speed.  The repeating function is documented starting from page 90 in the manual.
    • erotavlas's avatar
      erotavlas
      Tutor
      Hi,
      thank you for your reply. I imagine that the FastLane feature by Netgear is disabled by commercial reasons than hardware capability.
      I know that WNDR4300 can act as wireless repeater since also my old DG834G can do it. As specified in the manual and in the link that you provided, I should find a section Advanced > Advanced Setup > Wireless Repeating while in my router is not available. I have WNDR4300 v2 with latest firmware available V1.0.2.80 and this serial number 32m3415f00398. Under Advanced menu I have only Wireless Setting where I can specify parameters of wireless connection and WirelessAP where I can configure the router as AP, but only via LAN connection.
      Do you have any hint? What about install openWRT which is a firmware that allow to you any customization?
      Thank you
  • Try a factory reset and see if the repeater functions reappear.
    I don't have much experience with openWRT but I'm pretty sure DD-WRT can do what you originally asked for.
      erotavlas
      Tutor
      Hi,
      factory reset did not to change anything. So I'm looking for instal openWRT firmware because with respect to DDWRT it constantly receives updates (last on this september 15.05 vs 2013 of DDWRT).
      Thank you
      • ElaineM's avatar
        ElaineM
        NETGEAR Employee Retired
        Hello erotavlas,
        Hope this helps.
