Chearful
Dec 08, 2015Aspirant
Netgear WNR2000v2 - Cannot login
Hello, I currently have a WNR2000v2 router. I need to port forward something to my PC but I cannot seem to authenticate in.
You can see this in the GIF: https://gyazo.com/66de7a3d46eb225173f79ab4feaea325
I have verified that the password is correct, and I performed a factory reset on it (by poking a pencil in the reset button) but with no luck.
There are no errors, but it is literally putting me through a login loop which is rather frustrating.
Any help would be great - thanks.
Perhaps the router is not fully resetting itself.
Try to use a paper clip. If the same thing happens, it could be a hardware problem.
By the way, did you try to use a different computer and a browser?
- ElaineMNETGEAR Employee Retired
