brokenrouter702
May 06, 2022Follower
Network port capped at 100mbp
I've seen countless threads on this here and none have provided an answer. I have an ARIS Surfboard cable modem SB8200 I have the netgear R6080. When I run a speed test the most I can get is 100mbp I have a gig connection. When I remove the router and go from my modem to my PC I get 900+ mbps.
Why is it when I'm using the router and hooked up to the Ethernet port I'm limited to 100mbps? I'm using the cables supplied with the router and the cable modem. Also I only got this dinky router because my norton core is no longer being supported and I was getting 800+mbps on that device.
- KitsapMaster
Kitsap is correct. You didn't buy a gigabit router. You bought a fast ethernet router which only has 10/100mbps ports and not gigabit.
So your speed is going to max out at 94 (ish) mbps. If you want faster speeds, you need to upgrade to a gigabit router. And if you're using gigabit speeds, I wouldn't buy a base model gigabit device as even through struggle to hit gigabit over wired if you're using any extra features (armor, parental controls, access controls, traffic monitoring).
