Dharmajeet87
Aug 03, 2022Aspirant
Nighthawk router firmware update
My nighthawk router is blocking Hulu streaming after firmware upgrade.Please help.
Dharmajeet87 wrote:
My nighthawk router is blocking Hulu streaming after firmware upgrade.Please help.There's not enough there to go on.
What Netgear router is this? What firmware have you applied?
What do you mean by "blocking"? What are the symptoms?
If you can't fix the issue, the first move is to reset the router and set it up from scratch.
- Dharmajeet87AspirantRouter Model: R6400v2
Firmware Version: V1.0.4.122_10.0.95
I have tried to restore factory settings but no use.
Hulu is not working on any devices. Hulu error code: P-DEV302
I am able to login to Hulu but not able to watch any content. The above error is displayed after clicking on a content.- plemansGuru - Experienced User
I get what router you have. What modem/gateway is that router connected to?
Are you using armor or parental controls?
What modem/gateway is it connected to?
What error do you get?
Is it blocking it on all devices, just one?
- Dharmajeet87AspirantHi Sir,
A1: I am not using armor or parental control.
A2:It is R6400 v2
A3: I am getting P- DEV313 Hulu error code while streaming any content
A4: Yes it is blocking all the devices.- plemansGuru - Experienced User
1. what modem/gateway is the router connected to?
2. what firmware did you install?
3. did you try a factory reset on the router? Maybe an old setting is causing issues.
