callwill
Sep 07, 2021Aspirant
No 2.4Ghz network R6300V2
New to me R6300v2. When i set it up i enabled both the 2.5 and 5 networks with the same ssid and password. Later found i only have a 5Ghz network, no 2.4. Disabled the 2.4 and the enabled again, no luck. Disabled the 5Ghz still no 2.4. I have not tried different SSIDs, but did try different passswords for each, still no 2.4. Any advice....
first we update your firmware, then we can troubleshoot the wireless.
So try updating, then do a factory reset and reinstall
please try to stick to one post and respond on that post.
