toyne
Oct 20, 2016Aspirant
no wifi signal
since i changed the light settings i have huge problems with this stupid device. before it was working perfectly
i switched my lights to off (so only the power light is lit) and while i did this it asked me to update firmware or something so i did that as well.
ever since i have troubles. ive hard resetted it twice now.
the problem is as followed
i have cable connected to pc and tv and they are working fine
but my phone doesnt see our wifi signal (same goed for all other divices)
when i login to admin it states that the status of my wireless is off......................... somehow.
when i click it i get into a screen full of checkboxes.
| Geavanceerde draadloze instellingen (2.4GHz b/g/n) |
| radio of wireless router activate |
| Co-existentie 20/40 MHz activate |
| Fragmentatielengte (256-2346): |
| CTS/RTS-drempel (1-2347): |
| Preamble-modus |
i guess it has te do with the radio of wireless checkbox. but when i check it and say save the changes nothing changes :@
and stuff is not working still
- Retired_MemberOct 20, 2016look for a wifi off on button on router, and or push reset until power LED flashes
- Retired_Memberlook for a wifi off on button on router, and or push reset until power LED flashes
- toyneAspirant
already turned the device on/off several times. that didnt work.
like i said already resetted the whole thing twice as well
- Retired_Memberdid you Factory default it?
