cdysthe
Oct 10, 2021Virtuoso
Ny new Orbi RBR750 already registered, but not to me.
Hi, I have replaced my Orbi RBK50 system with a Orbi RBK752 system (one satellite on both). When I was setting up the new system I was told that it was already registered. I bought it on Amazon as a...
- Oct 10, 2021
You'd need to contact support to do so.
Click on "Mynetgear" at the top.
then my support---->contact support---->my subscription services.
You'll need to go through that route to get it register/switched.
cdysthe
Thanks. Contacted support through chat and the problem will be resolved.
Oct 10, 2021Guru - Experienced User
Hope they get it done on the first time and quickly! (don't have much faith in support)
- cdystheOct 10, 2021VirtuosoThey had to "escalate" it since the device was already registered in someone else's name. I can see why they have to make sure I'm not BS'ing. They said it would take a day or two.
- FURRYe38Oct 11, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-axThank you.
- cdystheOct 11, 2021Virtuoso
I may be stupid but I do not understand how to post in that forum. I get the same post composer as here and I can not find my Orbi system in the dropdown. Confused, sorry! :)
