GreyBeard1948's avatar
Mar 27, 2021
Orbi RBS40V. Netgear sent firmware update
I have an Orbi Rbr50 WiFi router with 2 satellites. One of the satellites is an Orbi Voice rbs40v. Netgear sent an email to upgrade the rbs40v but every time I try to update the firmware I get an error message. My Rbr50 firmware is v2.7.2.104.
Does the Orbi Voice need a firmware update by itself? I could use some help please.
  • plemans's avatar
    Mar 28, 2021
    You are on the current firmware version.
    I know that there was issues over the last few days with the auto-update server but you're on the most current so you should be good.
    • GreyBeard1948's avatar
      GreyBeard1948
      The firmware version is shown as V2.6.2.4 on my Mobile Netgear application
        GreyBeard1948
        Was reply incorrect? I just need to know why I keep.getting an error message when I try to check for new firmware. In the past when I Checked the firmware it would state I have the most current update or would tell me to update. Do the router and the voice satellite have to be on the same firmware version?
        I am not good at this and really need some help. My WiFi numbers are fine as is everything else.
