HelpMe3
Nov 07, 2019Tutor
Password change without access in my router
Hello community, i have the router Wireless-N 300 WNR2000 (i dont know the version) i bought it years ago,i havent the CD..
So,i dont remember the password i had and the URL in the browser where i can change the pass dont let me connect because im not connected in the netgears router..
the question is how i can connect to my netgears router :)
sorry if my problem have solved in other topic but i ll appreciate your help and sorry if my qiestion is a little silly.
Look at the label on it. If there isn't a "V number", then it is V1.
If you visit the support pages:
you can feed in the model number and find all the documentation for your hardware.
If you have forgotten the admin password, then only option may be a factory reset:
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
HelpMe3 wrote:
... sorry if my qiestion is a little silly.
There is no such thing as a silly question. Only silly answers.
Can you log into the router via a hardwired connction? If so, all you need is the admin password to the gui.
If you've forgotten this info, then you'll be needing to reset the device back to factory and use the factory login info.
- HelpMe3Tutor
how i can log with hardwire connection ? and where i can find the admin pass ? i havent any cd or paper..
about the return of the device i dont think this will help after so many years
- HelpMe3Tutor
Mate problem solved,i restore the whole thing and i have access in everything...thnks a lot,i havent idea for this button i didnt see it before
