SteveDavisPsyD's avatar
Jul 12, 2019
Password Reset on AC1600
I am trying to update the firmware on my modems (I have two) and have forgotten my login and password to the modem (C6250/AC1600 WFI Cable Modem Router). I know I have changed the password, but I am not sure about the login name. My other router sent me to a password recall screen, but this router is just kicking me out. How can I do a factory reset on this modem/router?
  • > I am trying to update the firmware on my modems [...]
    > [...] (C6250/AC1600 WFI Cable Modem Router) [...]
       How did you propose to do that on a DOCSIS cable modem+router?  Is
    there some actual problem which you are trying to solve?
    > [...] My other router [...]
       Same model, or some other (unspecified) device?
    > [...] How can I do a factory reset on this modem/router?
       Same as on any other Netgear router?  What did your Web search find
    for terms like, say:
          netgear  router  password  reset
       Visit http://netgear.com/support , put in your (actual) model number,
    and look for Documentation.  Get the User Manual.  Read.  Look for
    "Factory" or "reset"?
       First, you might want to look for "firmware".
          https://kb.netgear.com/000036375
    • Maybe I wasn't clear. I wanted to see if I could update my firmware (i know how to do this). I was unable to log into the router and could not remember my password. I was hoping you could help me recover my password or reset the modem. I have figured out how to reset the modem and everything is ok. Thanks.
      • antinode's avatar
        antinode
        Guru
        > Maybe I wasn't clear. [...]
           Yup.  Still true.
        > [...] I was unable to log into the router [...]
           What is your "the router"?
        > [...] I have figured out how to reset the modem [...]
           What is your "the modem"?
        > [...] I wanted to see if I could update my firmware (i know how to do
        > this). [...]
           What is your "my firmware"?  Is it related in some way to your
        "the router" or your "the modem"?
           Perhaps you know what you're doing, but evidence is sparse.
  • michaelkenward's avatar
    michaelkenward
    Forget it. You can't update the firmware on a cable modem. Only the ISP can do that.
    What’s the latest firmware version of my NETGEAR cable modem or modem router? | Answer | NETGEAR Support
    If your firmware is outdated, you cannot manually upgrade your cable modem’s or modem router’s firmware. You must contact your Internet service provider (ISP) to upgrade your firmware.
