1JohnDavid1's avatar
1JohnDavid1
Initiate
Apr 04, 2018
phishing email or authentic? How to know
I received a NETGEAR notice of a firmware update, but th elinks went to "click.e.netgear.com" which did not seem right to me.  The email looked auithtic and I was able to obtain the current update via NETGEAR Genie (avoiding all links in the email.  Still, I'm wondering if this was an authentic email.  Scammers are getting crafty.  Thanks in advance for you help.
  • schumaku's avatar
    schumaku
    Discussed and explained several times in the community.
    What should be wrong with that?
    Definitivley authentic - assuming you received the same as everyobody else.
    Netgear isn't really crafty - it's a lame message, reminding to many receivers as Scam.
