mfali
Jul 17, 2018Aspirant
Port Forwarding Error - Not working
I have a Netgear D6300AC wireless router, I had setup a port forwarding for RDS 3389 to one of my PCs on my network, however when I try to delete that entry from port forwarding list and try to setup...
- Jul 18, 2018
Manage to resolve the Issue..
I tried doing a reset again using the web interface rather than button reset.
The web interface reset did the trick - updated the firmware once again and the issue is now resolved.
antinode
Jul 17, 2018Guru
> [...] when I try to delete that entry from port forwarding list and
> try to setup a new rule for another device using same port 3389 it
> doesn't let me do that, [...]
After you "try to delete that entry", is it gone? Copy+paste of your
actual port-forwarding rules might be interesting. Similar for the
actual "a new rule" which you are trying to add.
> [...] UPnP [...]
Is UPnP disabled? It probably should be, if you're using port
forwarding.
> I tried factory resetting the router few times, [...]
That should do the job, assuming that your "factory resetting" really
did a settings reset. Did all the usual settings (passwords, SSIDs,
...) get reset as expected? (Did the LED indicators do interesting
things?) If a proper reset did not help, then I'd guess that there is
something wrong with your port-forwarding rule specification(s).
Also, does the target system have a fixed (static or reserved
(dynamic)) LAN IP address? (Without that, a port-forwarding rule could
be useless, even if you could get it installed.)
mfali
Is UPnP disabled? - Yes it is.
Yes the reset was successful as it has removed all the firewall rules, port forwarding rules and SSIDs, I thought the same that it is not working, therefore I tried resetting it multiple times.
The target system have a fixed.
Bit Weired situation, but interesting to find a resolution for it.
Thanks
