carcanox32
May 31, 2022Aspirant
Port Fowarding r6120
hello i can't seem to open port with my router i was working well before i move out of my old place
my router is connected to a modem.
Here what i try so far is:
i open a port through my router the port was 12050 TCP and UDP
i check if the port was open with Portforward.com and it say that is not open
i try different port
i try to disable my window firewall and make rule for the software i want to use the port
i made a static ip for my computer
after all this i can't figure what wrong cause at my old place everything was working fine
if you guy could help me it would be really appreciate
if you need more info just said it.
thanks !
window 10
router Version is :V1.0.0.82
model: R6120T
The software i want to use port is BYOND.
- microchip8MasterOnline port checkers need something listening on the port to report it open. If you have no service listening on that port(s), they'll report it as closed or stealth
what modem/gateway is the router connected to?
- CarmitaYaconoAspirant
I hope you find your best answer here https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Port-Fowarding-r6120/m-teatime-p/2228732.
Have a nice day to all of you. i am going to bookmark this thread if you want any further details then contact me here.
Thanksđ
- carcanox32Aspirant
so i did try to use my port with my software but it didnt work ether.
and i just check and my router is plug on a tiny box outside im with xplornet
anyone ?
What modem/gateway is your router connected to?
there is no modem. i dont see one, my router is connected to a little box outside and then on the antenna on the roof
