2Torr
Aug 25, 2021Follower
Power Supply Plug size for GS308E
I have a quick question about the power supply for the Netgear GS308E. Does anyone know what the power adapter barrel plug size is? For example, is it 2.1mm I.D. x 5.5mm O.D. ? Thanks, Ed
michaelkenward
Aug 26, 2021Guru - Experienced User
My experience is that Netgear does not discriminate between its different product ranges when it comes to those dimensions. Routers and switches are the same. (Just checked.)
But you might get more help in the appropriate section for your hardware. That's probably here:
Switches - NETGEAR Communities
You are more likely to find a switch owner there.
