SumanthD's avatar
SumanthD
PPPoE is not working
I have recently configured PPPoE in my Router. It was working fine for some time (4-5 days).
After that it stopped working.
If I change the setting (Does your Internet connection require a login? to NO), network is workfing fine.
I have reset the router and tried rebooting the router but nothing is working.
Other settings:
Internet IP Address - Dynamic
DNS - Automatic from ISP
MAC - Default
Internet port Details:
PPPoE
MAC Address B0:7F:B9:C7:5B:99
IP Address 0.0.0.0
Connection PPPoE
IP Subnet Mask 0.0.0.0
Domain Name Server 0.0.0.0
Without PPPoE
IP Address 172.16.64.179
Connection DHCPClient
IP Subnet Mask 255.255.254.0
Domain Name Server 103.242.152.38
8.8.8.8
Model: R6220
Router Firmware Version: V1.1.0.50_1.0.1
Windows 7
Can someone help me on this.
Thanks,
Sumanth D.
  • Hi SumanthD,
    1. Please confirm with your ISP if your connection should be configured as PPPoE.
    2. If the DHCP settings work, it is most likely that that is how it should be configured.
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi SumanthD,
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi SumanthD,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
      • SumanthD's avatar
        SumanthD
        Hi Dexter,
        Thanks for the information.
        Issue is from ISP end.
        You can mark this discussion as closed.
