Rene1973
Jan 15, 2023Tutor
Project: print something via my R6250 USB port while R6250 is connected Wirelessly to new isp router
Hello there !
i have a little project: basically i would like to give my trusty old Lazer printer some WIFI connectivity.
Here's a splanation:
i want to use my Netgear R6250's WIFI and USB port to connect my printer, then i have to connect the R6250 to my new modem/router (new isp) but i cannot use an ethernet cable to connect the 2 routers
So this has to be done via WIFI
I thought maybe using the R6250 as an extender, repeater or Access Point to link the 2 routers. it would also give better WIFI coverage and use its USB port.
The new router/modem is a CODA-4680-FIZ (2A)
Firmware v7.2.4.5.2b8
WIFI: 802.11 a/n/ac, 2.4/5Ghz
My router is a Netgear R6250
Firmware V1.0.4.48_10.1.30
The printer is an old Brother HL-2040 with usb and no wifi.
How would i do that ?
- plemansGuru - Experienced UserThe R6250 doesn't have a repeater/extender mode. Your only option to hit all the points you want would be AP mode which would require it to be hardwired in. If you set it up in bridge mode, it wouldn't repeat its signal and would just use the wireless for router---router communication. - Rene1973Tutorthanks for your answer Plemans! ok, so bridge mode it is ! is there a tutorial to accomplish this ? - michaelkenwardGuru - Experienced User
 Rene1973 wrote:
 thanks for your answer Plemans! ok, so bridge mode it is ! is there a tutorial to accomplish this ? Manuals are always a good place to start.
 Visit the support pages:
 Support | NETGEAR
 Feed in your model number and check the documentation for your hardware.
 Check the section in the manual Set up the Router in Bridge Mode
