required_alias
Jun 13, 2024Guide
R6050 as AP
Several 6050 as AP posts, but none I can find with this problem.
Trying to connect my 6050 as an AP. I can log in, get to ADVANCED>Wireless AP, and hit APPLY. Progress bar gets to about 90%, stays there for several seconds, and I get a 'Network timed out.' Tried that 4x. How do I avoid the timeout?
Most likely due to the IP address has changed for the router after you configured AP mode and hit apply, the router reboots and expects to get a new IP address from the host router the R series router is connected too.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
Try a Static IP address Configuration for AP mode?Yeah, that's the web site I used. Maybe I don't understand. Do I need to change the 6050 IP address to match the Asus (e.g., 10.10.10.1) or the 6050 SSID or both?
Try setting the static IP address on the R series router to 10.10.10.60 for AP mode. Gateway should be what you have set on the host router, normally 255.255.255.0 and Gateway would be 10.10.10.1. DNS can be same as 10.10.10.1 or any custom DNS if you want to use something different.
