ckbeme
Oct 19, 2016Aspirant
R6100, I keep losing IPV6 connectivity
Greetings Gear Group :manindifferent: Running Windows 10 Pro 64bit 1607... I just noticed this 2 or 3 weeks ago. My Samsung Galaxy S6 Always had a link speed of 867 Mbps. One day it was slow ...
- Oct 25, 2016
Hi ckbeme,
1. Please try disabling QoS entirely and check if the issue persists.
2. Please make sure that you are using WPA2 for security to get the optimum speed.
3. Please make sure that your devices are connected to the 5GHz band since the 2.4GHz band is only up to 300Mbps.
4. The current router that you have does not have Gigabit ports so you will need to upgrade in the event that you switch to the new service.
Dexter
Community Team
ckbeme
Oct 25, 2016Aspirant
Dexter,
Sorry I forgot to mention this in my reply. For the past week, my laptop and desktop WiFi adapters are showing to be Wireless n connections, and they are both ac, rated up to 867 Mbps. They have always shown to be Wireless ac until this past week. My Ethernet connections are also showing Wireless n instead of ac. I haven't changed anything. I updated drivers and checked firmware about 3 months ago. I check my firmware at least once a week.
Do you think my Router is going bad?
Also, Yes my firmware is current. And drivers are current on all my Ethernet and WiFi adapters.
I'm going to be getting a really big upgrade on my internet speed. Comcast is doing a special in my area. Get This: 265 Mbps!!
I'm not really in the best shape financially to upgrade my Router, but I have the R6100 AC 1200, and the stupid guy that helped me at the store said "You don't need to pay extra for Gigabit Lan ports"
These high speeds were all new to me. I have a Gigabit Ethernet card in my desktop and laptop. So my Beast desktop that I built is slower than my laptop on the Internet link speeds. Grrrr.
Anyway, my router only had a year warranty, and it's 2 years old.
Thanks
DexterJB
Oct 25, 2016NETGEAR Moderator
Hi ckbeme,
Dexter
Community Team
- ckbemeOct 26, 2016Aspirant
Hey Dexter,
Thanks for the advice. I've disabled QoS, we'll see how it goes.
And I'm definitely getting a new Router that has Gigabit LAN ports. I'm even thinking of getting a Wi Fi adapter for my desktop. I have verified that my DOCSis modem is plenty fast enough for the new
speeds.
And yes, all of my devices connect to the 5 Ghz speed except my network printer. It can only handle 2.4 band. I can't even find in the specs what wireless speed it supports, or what mode of wireless it has.
But it doesn't like the 5Ghz band.
Thanks again for your help.
