Corwin9s
Sep 15, 2017Aspirant
R6100 wifi Issues
hello. I'm on Windows 7 computer and I use the R6100 firmware 1.0.1.14.
Problem: wifi stops working suddenly and internet is of course no more reachable.
Solution: reboot the R6100
this is working... but it's quite painful to do this several time per hour. Any suggestion, help ?
Thanks in advance
Hi Corwin9s,
1. Have you tried doing a factory reset on the router?
2. Does the issue persist on both bands (2.4GHz and 5GHz)?
3. Have you tried changing the wireless channel for either bands?
4. Are your wired devices affected?
DexterCommunity Team
- Corwin9sAspirantHello. I rebooted but still ko.
I did all you said except hard reset: still ko.
Wi-Fi is ko, cable connexion is ok.
Next try: hard reset. How to do this? How to keep access?
