Mahadi132
Jun 09, 2022Aspirant
R6120 Power LED is blinking
Recently I buy this R61200 router ,but the Power LED is blinking all time. i try to upload firmware TFTP client on Microsoft Windows but the problem is when i turn my router off for 10 seconds but Power LED to light not orange and not start flashing. i'm flowing the all step but 8-10 not work .How do I upload firmware to my NETGEAR router using a TFTP client on Microsoft Windows? | Answer | NETGEAR Support
..please help me
- wcalifasProdigy
There's videos on youtube you can check out by searching "how to debrick a router" you can download tftp2.exe and use that to try unbricking your router.
If this is a new router an it behaved like that our of the box, then it is a dud and should go back to whoever sold it to you.
i try to upload firmware TFTP client on Microsoft Windows but the problem is when i turn my router off for 10 seconds but Power LED to light not orange and not start flashing.TFTP is not the simplest of tasks. It might help to follow one f the various videos out there.
Timing is the essence.
- Mahadi132Aspirant
I'm download TFTP not work ,, than try to download tftp2.exe but 403 error
I don't understand that.
You should not need to download anything. Enable TFTP in Windows and use that.
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
And do check that video.
- Mahadi132Aspirant
and im try nmrpflash but receive jeep -alive request (6),, not work
The window you show seems to be Windows Explorer.
You need to work out how to get the CMD prompt.
