oldenkafe
Feb 20, 2023Follower
R6120 Router won't renable wifi during firmware update
I have tried updating the firmware through the route admin page, it says the usual "3 minutes to update firmware", completes the progress bar but after that the router won't enable wi-fi. So the update page cannot connect to the router for the installation to progress. Anyone experienced this? Is there a workaround for this issue?
- microchip8MasterYou should use a wired connection when updating firmware. Don't rely on WiFi. Too many things can go wrong, and firmware update is a sensitive, critical operation.
So you can't connect back to the router?
What are the led's on it doing?
What firmware did you install?
what modem/gateway is it connected to?
Did you try a factory reset?
