nayeemlinkin
Apr 04, 2018Aspirant
R6220 - using a power bank for router power
Hello there... i want to use a power bank(10000mah, 2.01amp) for powering my R6220. i tested it.. and it runs smooth but my question is... is there any problem if i use in that way... cause router ne...
- Apr 04, 2018
> [...] i tested it.. and it runs smooth [...]
That's not what I'd expect, but you could get lucky.
> [...] router needs 12v/1.5a [...]
That's what the User Manual says, and I assume that the product label
on the R6220 agrees.
> [...] and um giving him 2.01amp( 5v power bank actually,idk it
> converts 5v to 12v or not).
If its label says "5V", then I'd expect its output to be 5V (which is
not 12V).
The RAPBB1006 is intended for use with USB-powered devices. How did
you connect it to the R6220? Some kind of USB cable? (That might not
be a good idea, but I don't know enough about the power circuitry in an
R6220 to make predictions about what can go wrong.)
> what can i do, if its not good for my router.. ? do i need a 5v to 12v
> booster usb to dc power cable? or anything else...?
For proper operation, you would probably need a 12V power supply. If
the R6220 ever wants to use 12V at 1.5A, then that would be 18W. 5V at
2.1A is 10.5W. The ratings of an RAPBB1006 suggest that it can't supply
as much power as an R6220 can demand, even if you converted its 5V
output to 12V.
antinode
Apr 04, 2018Guru
not 12V).
output to 12V.
