nayeemlinkin's avatar
nayeemlinkin
R6220- power led blink continiously for 10-12sec
when i start my r6200 power led blinks continiously for 10 sec but everything is okay.. router is working fine... but why power led is blinking? i got this router from warranty... after previous one got brick..
  • Hi nayeemlinkin,
    Welcome to the community!
    Does it stay steady afterwards? If yes, that is part of the boot up process.
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi nayeemlinkin,
    Dexter
    Community Team
    • nayeemlinkin's avatar
      nayeemlinkin
      yes it stay steady after 10/12 sec... but i have 2 Router, both of them are same model R6220.. one blink in start up another one never blink.... thanks
      • michaelkenward's avatar
        michaelkenward
        If you have two routers on the same network, you should configure them to avoid conflicts. Usually this means using one router in access point mode.
        There is a manual for the R6220 somewhere at the end of this link:
        >>> R6220 | Product | Support | NETGEAR <<<
        See page 127.
