Delaynomore
Oct 03, 2015Aspirant
r6220 I can't change wifi tranfer out put control to super wifi
It used to be have a option to control the output power in Advanced MENU before upgrade the fireware.
Hi Delaynomore,
All firmware versions (1.0.0.14, 1.0.0.16, 1.0.0.17, and 1.1.0.31) of the R6220 do not provide the option to modify the transmit power for the wireless signal. Did you own a different NETGEAR router before?
Dexter
Community Team
- DexterJBNETGEAR Moderator
Hi Delaynomore,
1. Are you referring to the wireless output power?
2. What is the current firmware version of the device?
3. What firmware version were you using before?
4. Please provide a screen shot of the setting if possible.
Dexter
Community Team
- DelaynomoreAspirant
I don't recall the version
Hi Delaynomore,
Dexter
Community Team
1.yes
- DelaynomoreAspirantno
