jacoc's avatar
jacoc
R6220 poor wifi cover
Hi.
I have the R6220 router. On the box the cover is 110m2 but i have extremely poor coverage in my room that is 5m away.
How do I go about fixing this error?
  • plemans's avatar
    A little more details help.
    1. what are your interior walls made of? Certain materials block wifi better than other.
    2. what actual speeds are you getting? Over wired? Over 2.4ghz? Over 5gh?
    3. what firmware is on the router?
    4. what modem/gateway is it connected to?
    Details are key.
    • jacoc's avatar
      jacoc
      Hi,
      I have normal brick and plaster walls.
      My firmware is 1.1.0.110.
      2.4ghz - 18 up and 10 down
      Fibre cable connects to router directly.
      • plemans's avatar
        jacoc wrote:
        Hi,
        I have normal brick and plaster walls. ----brick and plaster walls block wifi very well.
        2.4ghz - 18 up and 10 down-----what do you pay for for speeds? what speeds do you get over 5ghz? 2.4ghz is a slow network.
        Fibre cable connects to router directly. ---what ONT do you have?
