Adithya123
Sep 22, 2018Aspirant
r6220 Router access issue
Hi All,
My router has been setup and internet works Via 2.4Ghz and 5 Ghz. But when I'm trying to access the router setting using 2.4ghz it does not open but when I use 5ghz it opens. (used 192...
- Sep 22, 2018
I had to do factory reset and configure the router manually again. It works now. Thanks a lot
michaelkenward
Sep 22, 2018Guru - Experienced User
Adithya123 wrote:
But when I'm trying to access the router setting ....
Access the router setting with what?
Adithya123 wrote:
Firmware is the latest V1.1.0.68_1.0.1 I'm thinking this issue started after I have upgraded the firmware.
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
This is a nuisance because you then have to reconfigure the device all over again.
You can backup your settings before you reset and restore them later. But that may just bring back the fault. Then again, at least you will know if the reset fixed the problem.
- Adithya123Sep 22, 2018Aspirant
- michaelkenwardSep 22, 2018Guru - Experienced User
Glad that the old trick worked.
Painful, I know, but always worth trying.
