Adithya123
Sep 22, 2018Aspirant
r6220 Router access issue
Hi All,
My router has been setup and internet works Via 2.4Ghz and 5 Ghz. But when I'm trying to access the router setting using 2.4ghz it does not open but when I use 5ghz it opens. (used 192...
- Sep 22, 2018
I had to do factory reset and configure the router manually again. It works now. Thanks a lot
Adithya123
michaelkenward
Sep 22, 2018Guru - Experienced User
Glad that the old trick worked.
Painful, I know, but always worth trying.
