lordhades's avatar
lordhades
R6220 V1.1.0.86_1.0.1 firmware update?
Hi,
Got an update to firmware version V1.1.0.86_1.0.1 for the AC1200/R6220.
I cant find the firmware update notes anywhere but the internal router check found that update and applied it. After the update, trying to login to the router gave me a prompt to enable auto firmware updates and router analytics for this router.
I was wondering if anybody could elaborate what was in this update and whether it was official.
Thanks in advance
    • lordhades's avatar
      lordhades
      Yep. That link is the exact thing I got. I haven't enabled them because I wasn't sure if their update server had been hijacked or not since there is no official changelog for this firmware.
      • Phesix's avatar
        Phesix
        Yeah, it seems like an odd name to give that link. I'm not sure what to think about it, but it could just be a hot fix like I was told, and the full version will be updated later.
