Sctwigg
Jan 26, 2017Aspirant
R6300-AC1750 Router doesn't connect to CM600
My R6300 Router will not connect to my new netgear CM600 cable modem. The internet light remains amber. I've done the appropriate power down/reboots on the modem and router with no success. I've done ...
- Feb 04, 2017
I started thinking about firmware after my last post. I did some testing and found that if I reset the reset the router to the factory settings and then reverted to the previous firmware for the R6300 (1.0.2.76) the Router would then connect to the DHCP on the CM600. I could then update to the current firmware and still retain the internet connection. If I applied a saved cfg file to the router from current firmware I could replicate the problem with the internet connection. The repair process was repeated: clear the cfg settings by resetting the router to the factory settings, revert to the previous firmware and then update to the current firmware. Everything was fine with the internet connection with the CM600
Cpfms
Jan 28, 2017Apprentice
Did you enable Downstream QoS by chance? There seems to be an issue with that setting basically bricking the router in the .18 firmware.
- DexterJBFeb 02, 2017NETGEAR Moderator
Hi Sctwigg,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team- SctwiggFeb 03, 2017AspirantI tried both without any change
It was enabled and I've shut it off now without seeing a change after power cycling and rebooting. Interestingly, the Router worked fine with a previous CM600 with QoS enabled.
- CpfmsFeb 03, 2017Apprentice
There was something in the .18 firmware that caused Downstream QoS to brick the ability of it to get an IP from DHCP while in router mode.
- SctwiggFeb 04, 2017Aspirant
Now after looking at everything else, it may have been the QoS setting that killed the connection with the first CM600 and, assumably the reason why the second never worked. With the first CM600 the quality of the connection on the network was fine at first and slowy started deteriorating. Then it got to the point where I was geeting dropped connections with an online game and speedtests were showing a great deal of lag, etc. That's why I returned the first one, I was thinking that it was a hardware issue with the LAN port on the CM600.
