CM600
1 TopicR6300-AC1750 Router doesn't connect to CM600
My R6300 Router will not connect to my new netgear CM600 cable modem. The internet light remains amber. I've done the appropriate power down/reboots on the modem and router with no success. I've done the MAC spoofing of the address of the computer that I used to set up the CM600 on the R6300 with no success. I can connect directly to the CM600 modem with a laptop and internet is fine (the modem is activated with my ISP). Firmware is up to date on all equipment. Additionally the router connects to my CM400 without issue and connected to a previous CM600 before its WAN port died. Does anyone have thoughts as to what I should try next to troubleshoot this?Solved8.3KViews0likes16Comments
