CM600
7 TopicsHelp with ac1900 R7000 nighthawk, cm600 cable modem, and ac2200 wifi extender
Would it be possible to run an ethernet cable from my cm600 cable modem to set nighthawk ac1900 R7000. Then connect an ethernet cable from my ac1900 to my ac2200 wifi range extender for the wifi. Would i have to set my ac1900 in bridge mode? Also this is for the purpose of not only running an ethernet to the ac2200 but another one to my playstation 4 as well. The ac2200 has the option to flip it as an access point instead of a range extender. Therefore i would be able to connect my wifi devices to the ac2200. Basically it would go internet -> cm600 -> ac1900 ->lan cable to ps4, lan cable to ac2200. Sorry I am new to this. Is this completely redundant? I ask this because when i set my ac2200 as extender mode, it will screw up my LAN connection on my ps4 when anyone connects to the ac2200 for some reason. I dont know what settings i'd have to do to fix that.. just wondering if the setup i described above would work just as well.1.7KViews0likes3CommentsInconsistent network speed
Hello all, I been having issues with my internet speed connection. I have Xfinity Comcast internet, 80Mbps download and 12Mbps upload. I have Netgear CM600 modem and using that with Netgear Nighthawk wireless router. I been trying different things with restarting the router, upgrading firmware on router etc., i would get correct speeds after router restart, but shortly after maybe 10 min later i get low speeds again. And it varies anywhere from 1Mbps to 80Mbps. I use the testmy.net to test the internet speed and its very random i get anywhere in that range from 1Mbps to 80Mbps. I went out today and purchased a new linksys router for testing purposes so that i can see if the router is the issue, but i am getting the same internet speed drops on new router, which makes me think its the Cable modem thats causing the issue. That said i have also tried restarting the cable modem as well and like with router restarts, the speed are ok for 10 min and they drop again. The cable modem shows all lights in green after restart. I also went in and copied the down and up stream channels perhaps someone can make better sense out of this. I am not sure how to interpret the signals bellow? Any help would be much appreciated. Frequency start Value This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. Starting Frequency 609000000 Startup Procedure Procedure Status Comment Acquire Downstream Channel 609000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enable BPI+ IP Provisioning Mode Honor MDD IPv6 only Downstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 16 609000000 Hz -6.6 dBmV 36.5 dB 717 306 2 Locked QAM256 1 519000000 Hz -5.9 dBmV 36.2 dB 857 603 3 Locked QAM256 2 525000000 Hz -5.8 dBmV 37.8 dB 786 585 4 Locked QAM256 3 531000000 Hz -6.0 dBmV 37.9 dB 905 333 5 Locked QAM256 4 537000000 Hz -6.0 dBmV 37.7 dB 801 439 6 Locked QAM256 5 543000000 Hz -6.0 dBmV 37.6 dB 795 456 7 Locked QAM256 6 549000000 Hz -6.2 dBmV 34.8 dB 722 541 8 Locked QAM256 7 555000000 Hz -6.1 dBmV 36.5 dB 686 545 9 Locked QAM256 8 561000000 Hz -5.7 dBmV 34.1 dB 661 483 10 Locked QAM256 9 567000000 Hz -5.9 dBmV 34.8 dB 696 395 11 Locked QAM256 10 573000000 Hz -6.2 dBmV 30.9 dB 288866 89853 12 Locked QAM256 11 579000000 Hz -6.4 dBmV 33.9 dB 138318 1992 13 Locked QAM256 12 585000000 Hz -6.8 dBmV 37.2 dB 770 388 14 Locked QAM256 13 591000000 Hz -6.0 dBmV 37.3 dB 769 328 15 Locked QAM256 14 597000000 Hz -5.6 dBmV 37.3 dB 686 114 16 Locked QAM256 15 603000000 Hz -5.6 dBmV 32.6 dB 771 175 17 Locked QAM256 17 615000000 Hz -6.1 dBmV 33.4 dB 0 0 18 Locked QAM256 18 621000000 Hz -5.6 dBmV 32.0 dB 0 0 19 Locked QAM256 19 627000000 Hz -5.1 dBmV 37.9 dB 0 0 20 Locked QAM256 20 633000000 Hz -5.0 dBmV 38.1 dB 0 0 21 Locked QAM256 21 639000000 Hz -5.4 dBmV 37.8 dB 0 0 22 Locked QAM256 22 645000000 Hz -5.8 dBmV 36.7 dB 0 0 23 Locked QAM256 23 651000000 Hz -5.6 dBmV 25.6 dB 60 559 24 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 Upstream Bonded Channels Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 65 5120 Ksym/sec 36400000 Hz 54.0 dBmV 2 Locked ATDMA 66 5120 Ksym/sec 29500000 Hz 54.0 dBmV 3 Locked ATDMA 67 5120 Ksym/sec 22600000 Hz 53.3 dBmV 4 Locked ATDMA 68 5120 Ksym/sec 15700000 Hz 53.3 dBmV 5 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 6 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV Thank you, Mike2.4KViews0likes1CommentCM600 Status page 192.168.100.1 does not work on any of my computers. Works on cell.
First off, I can load the status page fine on my cell phone. Everything works right on it. However, it looks like none of the browsers on any computer I have tried supports it correctly. I can login to it but it is messed up. It looks like this: http://imgur.com/a/7NNao When I load it on my phone it says firmware version is V1.01.12. My ISP is Comcast. I can access the cable modem status on my computer, these are results: Cable Connection Frequency start Value This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. Starting Frequency Startup Procedure Procedure Status Comment Acquire Downstream Channel 621000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enable BPI+ IP Provisioning Mode Honor MDD IPv6 only Downstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 11 621000000 Hz -1.6 dBmV 39.5 dB 0 0 2 Locked QAM256 1 561000000 Hz -1.6 dBmV 39.5 dB 0 0 3 Locked QAM256 2 567000000 Hz -1.6 dBmV 39.7 dB 0 0 4 Locked QAM256 3 573000000 Hz -1.7 dBmV 39.6 dB 0 0 5 Locked QAM256 4 579000000 Hz -1.6 dBmV 39.7 dB 0 0 6 Locked QAM256 5 585000000 Hz -1.8 dBmV 39.6 dB 0 0 7 Locked QAM256 6 591000000 Hz -1.7 dBmV 39.5 dB 0 0 8 Locked QAM256 7 597000000 Hz -1.6 dBmV 39.6 dB 0 0 9 Locked QAM256 8 603000000 Hz -1.7 dBmV 39.5 dB 0 0 10 Locked QAM256 9 609000000 Hz -1.7 dBmV 39.4 dB 0 0 11 Locked QAM256 10 615000000 Hz -1.5 dBmV 39.5 dB 0 0 12 Locked QAM256 12 627000000 Hz -1.4 dBmV 39.5 dB 0 0 13 Locked QAM256 13 633000000 Hz -1.3 dBmV 39.4 dB 0 0 14 Locked QAM256 14 639000000 Hz -1.1 dBmV 39.5 dB 0 0 15 Locked QAM256 15 645000000 Hz -0.9 dBmV 39.6 dB 0 0 16 Locked QAM256 16 651000000 Hz -1.0 dBmV 39.5 dB 0 0 17 Locked QAM256 17 657000000 Hz -1.2 dBmV 39.4 dB 0 0 18 Locked QAM256 18 663000000 Hz -1.3 dBmV 39.4 dB 0 0 19 Locked QAM256 19 669000000 Hz -1.6 dBmV 39.0 dB 0 0 20 Locked QAM256 20 675000000 Hz -1.7 dBmV 38.9 dB 0 0 21 Locked QAM256 21 681000000 Hz -2.3 dBmV 38.6 dB 0 0 22 Locked QAM256 22 687000000 Hz -2.5 dBmV 38.6 dB 0 0 23 Locked QAM256 23 693000000 Hz -2.8 dBmV 38.2 dB 0 0 24 Locked QAM256 24 699000000 Hz -3.1 dBmV 37.8 dB 0 0 Upstream Bonded Channels Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 10 5120 Ksym/sec 23700000 Hz 42.0 dBmV 2 Locked ATDMA 11 5120 Ksym/sec 30100000 Hz 41.8 dBmV 3 Locked ATDMA 12 5120 Ksym/sec 36500000 Hz 43.0 dBmV 4 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 5 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 6 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV Current System Time: Thu Mar 09 14:42:13 2017 Help Center Show/Hide Help Center edit: I had previously used a rented gateway, I think it is trying to load the page for that perhaps? I don't know.Solved5.4KViews0likes2CommentsR6300-AC1750 Router doesn't connect to CM600
My R6300 Router will not connect to my new netgear CM600 cable modem. The internet light remains amber. I've done the appropriate power down/reboots on the modem and router with no success. I've done the MAC spoofing of the address of the computer that I used to set up the CM600 on the R6300 with no success. I can connect directly to the CM600 modem with a laptop and internet is fine (the modem is activated with my ISP). Firmware is up to date on all equipment. Additionally the router connects to my CM400 without issue and connected to a previous CM600 before its WAN port died. Does anyone have thoughts as to what I should try next to troubleshoot this?Solved8.3KViews0likes16CommentsIs Quality of Service (QoS) customizable on CM600?
Hi, I'm intersted in buying a new modem (CM600) that will allow me to prioritize my VoIP devices (a Polycom handset provided by my employer and a Verizon femtocell/network extender.) I've noticed in my current setup that voice calls occasionally get disturbed when my family is streaming Netflix. They often have 2 concurrent Netflix streams running while I'm making calls. I've tried searching, and have only briefly seen mention of "Advanced QoS" on the high-end modem. However, I'm unclear if this QoS is adjustable to suit my needs. I just want to provide the IP addresses of my two devices, and tell the modem that anything from those two devices gets prioritized. I'd appreciate a screenshot of the configuration screen, if available. I searched the Users' Guide, but didn't find anything. Thanks, JohnSolved4.5KViews0likes4CommentsCM600 + Router Port Forwarding
I'm trying to configure my router to port forward TCP 3389 so I can use Remote Desktop. I've tried two Netgear routers and both have the router blocking the forwarding effort. i see the router log showing an error (WLAN access rejected MAC error) so the router thinks it's protecting me from a spoofing attack when i use CanUSeeMe to check the port access. I've configured a number of netgear routers with port forwarding off of other devices but for some reason XFinity and this CM600 modem have me stumped. Any suggestions why the router is seeing any attempt to touch this port as an attack and blocking it? Thanks, PatSolved8.7KViews0likes9Comments
