Sctwigg
Jan 26, 2017Aspirant
R6300-AC1750 Router doesn't connect to CM600
My R6300 Router will not connect to my new netgear CM600 cable modem. The internet light remains amber. I've done the appropriate power down/reboots on the modem and router with no success. I've done ...
- Feb 04, 2017
I started thinking about firmware after my last post. I did some testing and found that if I reset the reset the router to the factory settings and then reverted to the previous firmware for the R6300 (1.0.2.76) the Router would then connect to the DHCP on the CM600. I could then update to the current firmware and still retain the internet connection. If I applied a saved cfg file to the router from current firmware I could replicate the problem with the internet connection. The repair process was repeated: clear the cfg settings by resetting the router to the factory settings, revert to the previous firmware and then update to the current firmware. Everything was fine with the internet connection with the CM600
Sctwigg
Feb 04, 2017Aspirant
Now after looking at everything else, it may have been the QoS setting that killed the connection with the first CM600 and, assumably the reason why the second never worked. With the first CM600 the quality of the connection on the network was fine at first and slowy started deteriorating. Then it got to the point where I was geeting dropped connections with an online game and speedtests were showing a great deal of lag, etc. That's why I returned the first one, I was thinking that it was a hardware issue with the LAN port on the CM600.
Sctwigg
- CpfmsFeb 06, 2017Apprentice
That's good and all but sucks if you have multiple port forwarding configs and other things going on that were working fine before the firmware/QoS setting broke things.
- CpfmsFeb 12, 2017Apprentice
Just spoke with Alex from Level 2 support and he basically said if this affected you then your hardware is defective and needs to be replaced. However, unless you are still inside your 90 day warranty period they will not be replacing the defective units and you will need to go out and buy a new one yourself. Well my next router d@mn sure won't be a Netgear, I'll tell you that. Not to mention we had to play phone and email tag for weeks just for him to tell me they aren't going to do jack to make this right.
Thanks for nothing.
- SctwiggFeb 12, 2017Aspirant
Sorry to hear that support hasn't been helpful
Since I did the reflash of the AC-1750 firmware I haven't had a problem with the DHCP requests from the router to the modem. It was a bit of a pain since the QoS isn't on and other port-forward settings, static ip addresses, etc. needed to be re-entered but it currently looks like I don't need to replace either unit. I'm thinking about flashing the router with dd-wrt firmware and using that interface and controls instead of the netgear firmware. My router is way out of warranty so I'm not concerned about warranty returns etc.
