BigdoginUSA
Aug 08, 2016Aspirant
R6300 Ethernet slow connection
This router has worked great for the past three years. I have a new ISP (Grande Communications) getting 400 Mbps and now all of a sudden the Ethernet ports out of the 6300 router are almost half of w...
- Aug 08, 2016
Do a factory reset and then do a minimal config. If speeds don't recover, consider a downgrade to the prior firmware with another factory reset and re-check speeds.
TheEther
Aug 08, 2016Guru
BigdoginUSA
Aug 20, 2016Aspirant
That did the trick. Tried factory reset, no luck, did the downgrade with another reset, got better, went back and upgraded to the current firmware and it improved again to where it's acceptable. It's still slower than coming directly out of the modem (by 100 MBps). Not sure why it does that.
Thanks again for responding and your help.
TheEther wrote:Do a factory reset and then do a minimal config. If speeds don't recover, consider a downgrade to the prior firmware with another factory reset and re-check speeds.
