mrkwanzaa
Nov 19, 2016Aspirant
r63002v2 slow speeds on 5ghz only
I have had a r6300v2 fo quite a while and have not had any problems with it. However recently with no noticable reason the 5ghz network started running very slow. My i have 60mbps download speeds fro...
- Nov 22, 2016
Hi mrkwanzaa,
You can try doing a firmware reflash then reset and reconfigure the router. The links below may help you out.
http://kb.netgear.com/app/answers/detail/a_id/23960
http://kb.netgear.com/app/answers/detail/a_id/9665Regards,
Dexter
Community Team
DexterJB
Nov 20, 2016NETGEAR Moderator
Hi mrkwanzaa,
1. Have you tried changing the wireless channel for the 5GHz band just for isolation?
2. Does the issue persist on all the devices that connect to the 5GHz band?
3. Have you tried resetting the router?
4. Have you tried changing the mode?
Dexter
Community Team
mrkwanzaa
Nov 21, 2016Aspirant
DexterJB About and hour after the factory reset, I noticed that my speeds seemed pretty good and ran a test again. After changing to an open chanel (but one I had previously tested on) I got the speeds I was looking for.
Thanks for your help!
- mrkwanzaaNov 21, 2016Aspirant
Sorry about this, but a few minutes after posting I found speeds were very slow again. I;m extremley confused and any help would be great
- DexterJBNov 22, 2016NETGEAR Moderator
Hi mrkwanzaa,
Dexter
Community Team
- mrkwanzaaDec 21, 2016Aspirant
Rolling back to firware version V1.0.3.2_1.0.57 fixed my problem. Thanks!
