mrkwanzaa
Nov 19, 2016Aspirant
r63002v2 slow speeds on 5ghz only
I have had a r6300v2 fo quite a while and have not had any problems with it. However recently with no noticable reason the 5ghz network started running very slow. My i have 60mbps download speeds fro...
- Nov 22, 2016
Hi mrkwanzaa,
You can try doing a firmware reflash then reset and reconfigure the router. The links below may help you out.
http://kb.netgear.com/app/answers/detail/a_id/23960
http://kb.netgear.com/app/answers/detail/a_id/9665Regards,
Dexter
Community Team
mrkwanzaa
Nov 21, 2016Aspirant
DexterJB About and hour after the factory reset, I noticed that my speeds seemed pretty good and ran a test again. After changing to an open chanel (but one I had previously tested on) I got the speeds I was looking for.
Thanks for your help!
mrkwanzaa
Sorry about this, but a few minutes after posting I found speeds were very slow again. I;m extremley confused and any help would be great
