JorgeUrbina's avatar
JorgeUrbina
R6300v2 and Facebook Wi-Fi
I am trying to achieve the same thing. Facebook wifi on NETGEAR Router R6300v2. I have the latest firmware V1.0.4.6_10.0.76. And when I go to the advanced tab, there is no facebook tab.  I have told my customer that this is the router to do the job and now I have let them down.
Do they support Facebook anymore or not ?  Any info you have is much appreciated
  • Hi JorgeUrbina,
    1. Please try updating to a much later version (1.4.0.8) of the firmware.
    2. The Facebook WiFi option is under Advanced > Advanced Setup.
    3. Please provide a screenshot if possible.
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi JorgeUrbina,
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi JorgeUrbina,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
      • dazmelb's avatar
        dazmelb
        Hey Dexter,
        I have a netgear r6300v2 with firmware V1.0.4.8_10.0.77 and when I set up the facebook wifi it allows me to connect and surf the internet but it doesnt require me to check into my selected facebook page. How do I fix this?
        Please help me asap!
        Regards
        Darryl Perera
  • Facebook wifi on the r6300v2 never work from past postings about the subject.
